rear dif. fluid change questions
I have a 99 Z with traction contol and abs with 3.23's. What kind of gear lube should I use in it? Synthetic? Do I need the limited slip additive? Is the limited slip additive compatible with the synthetic gear lube? What is the weight of the proper gear lube? Sorry about all the questions. I should probably read my manual huh?
Thanks to anyone that can help!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Jul 4, 2005 05:00 PM
