Ram Adjustable Clutch Master
Old Mar 30, 2007 | 04:01 PM
Vicious95Z28's Avatar
Any1 using this, do you guys like it, what's the part# and do I need to change anything
Old Apr 11, 2007 | 08:54 PM
teke184's Avatar
just installed mine on my 99z
it's a stock unit with the adjustable heim joint attached to the shaft
comes with a pin for the hyd line, and the small 0-ring
now on mine i had to do some annoying surgery...the little ball socket on the heim joint was too wide to allow the retaining clip for the clutch pedal to slide on.
so i had to delicately touch it up with a hand held grinder...since its hardened steel...which isn't easy on a piece of metal that is the diameter of a nickel.
the thickness of the joint on the stocker was 13.25mm....the RAM unit was 13.75mm
i shaved it down to 13 to be cautious.
Rod Bender
May 16, 2015 02:16 PM
Matt W
Apr 24, 2015 12:54 AM
Queens94z28
Mar 23, 2015 08:06 AM
Ringmaster72
Mar 19, 2015 03:32 PM
