question for A4 guys
Old Jun 26, 2005 | 09:50 PM
LUDA0840's Avatar
Question question for A4 guys
When you guys race do you start from first gear and move to second then D or do you just leave it on D, or do you use the overdrive gear? It seems that the overdrive gear pulls harder then the regular D.???
Old Jun 26, 2005 | 10:04 PM
TA2PLAY's Avatar
Re: question for A4 guys
Put it in the normal drive gear with o/d and drive it. The computer can shift it much better than you.
RansZ28's Avatar
Not sure if this should be in the tech section, but I start in D (3rd).
Old Jun 26, 2005 | 10:08 PM
1racerdude's Avatar
D is fine.Just don't use OD at the strip-- it will be short lived on a stock tranny.
If ya want it to shift at a different RPM,get it programed into your computer and then "stab it and steer"
BLinindoll's Avatar
put it in regular d and go... not o/d. regular d is the same as o/d except it uses an extra band in 2nd for extra holding power. DONT shift it like a manual. the 4l60e's cant handle it and it will create too much line pressure.
Old Jun 26, 2005 | 10:12 PM
blind527's Avatar
What do you guys mean leave don't put it in O/D but leave it in drive...
I have 1,2,3,D, so what would you guys recommend for daily driving AND the track? Is 3 supposed to be Drive and D=O/D?
Old Jun 26, 2005 | 10:19 PM
neil350's Avatar
I just leave it in 3, point it and flash it.
Old Jun 26, 2005 | 10:30 PM
BLinindoll's Avatar
Camaros have 1, 2, d, and o/d... Firebirds must be different, but yes, 3 is the dame as d... your "d" is really o/d. Put it in 3 at the track and go. For daily driving I just use o/d unless im racin from a stop light or something... then i throw it in d.
Old Jun 27, 2005 | 02:31 AM
LUDA0840's Avatar
well i have one of those shift kits and it shifts pretty good! just has that wheel hop when it shifts all hard.
Old Jun 27, 2005 | 09:13 AM
Gripenfelter's Avatar
If you have the 4L60E for 94+ cars you put it in 3rd or "D".
If you have a 700R4 with a raised redline like me, you need to manually shift it 1-2-3 in order to get it to shift at 7000rpm instead of 5700.
Old Jun 27, 2005 | 08:46 PM
BLinindoll's Avatar
No, you don't manualy shift a 4L60e... you change the shift points if you dont want it to shift at 5700 or put the manual kit in and do ALL the shifting ALL the time.
EDIT: Sorry... I forgot you said 700r4.... I'm pretty sure it's just the 4L60e that you can't shift.
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
