Problems with T56 gears
Old Apr 22, 2007 | 08:58 PM
sandman2100's Avatar
Unhappy Problems with T56 gears
Just started yeasterday while criusing around. Coming to a stop, I went to downshift to first and I it was like the clutch never left go. I had to stop, go back to 2nd, then to first again. It did this 2-3 times and now it seems to effect no other gears. Seems fine if I double clutch it, or push the pedal hard to the floor. It is also nearly impossible to get it into reverse unless you jam the shifter hard. I check the eng sensor fuse and it was fine, might be related to this problem, or it might be the reverse lockout solenoid?
I pulled the slave cylinder out and the boot and rod stayed on the fork? I had to pull it all out by hand. I'm not too sure how the LT1 setup is, but my last ride was one assembly (ROD, BOOT, CYLINDER) . I have no loss of fluid, no problem going from gear to gear if I go all the way down hard with the pedal. I put the slave back in and I had my wife pump the pedal with the resevoir cap off and no bubbles at all. The pedal feels fine and firm, and after a quick criuse around the block it seems it is hit or miss with first gear.
I ran all over town trying to track down a slave cylinder, no luck. Am I safe to drive this to work at least until I find a replacement?
Also:
Does anyone know the part numbers for the master/slave assembly for the 97?
** found the part number**
12559912
Just need some insight before I buy the assembly or the slave cylinder and waste the money
Last edited by sandman2100; Apr 22, 2007 at 09:24 PM. Reason: Found the part number
Old Apr 23, 2007 | 07:55 AM
Well, it made it to work with no problems....... new issue though.
Now she stumbles. Murphy's law eh? I just fixed a cracked edelbrock header, so that may have something to do with it. Wire prob touched the manifold. Luckily the SES light popped up (funny how I see this as lucky )
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
HectorM52
Jul 30, 2017 11:46 AM
1LEThumper
Jul 14, 2003 12:45 PM
slothgrant
Aug 22, 2002 03:01 PM
FireAm94
Aug 10, 2002 09:32 PM
