PROBLEM not shifting HELP
Old Nov 21, 2010 | 02:17 PM
MyFastTA's Avatar
I have a 383 just built....just went to drive it the first time today went out and it seems like it only has first gear...and it tries to shift I think but free revs. I did get what felt like second but only after i gave her some good rpms like 4500 to 5000...Its a brand new transmission does have a 2 yr 50k warantee. I have a 3000 stall converter in it also that is new. I am trying to figure out how to figure out whats goin on any help is much appreciated thanks in advance
Bryan
Old Nov 21, 2010 | 03:09 PM
Re: PROBLEM not shifting HELP
Any codes for the trans, the VSS or the TPS?
Old Nov 21, 2010 | 09:02 PM
MyFastTA's Avatar
havent pulled codes yet but after you said that i drove it had no speedo bet that has something to do with it
Old Nov 21, 2010 | 11:04 PM
TD95Z's Avatar
The VSS, as the name implies, reports vehicle speed to the PCM. Since the auto trans shift tables in the PCM use vehicle speed as one of the inputs, the lack of a VSS signal results in a no-shift condition. It also explains why your speedo doesn't work. If I had to guess, I'd say the wiring got damaged during the install.
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
