problem after installing gears...weird noise
Old Nov 20, 2009 | 10:02 PM
pboxfun's Avatar
Exclamation problem after installing gears...weird noise
I just finished installing 3.90 gears in to my 94 A4 10bolt. The problem i am having is that when i left off the gas and turn the steering wheel towards the right while making a turn, the rear end makes a weird grinding noise. And the farther towards the right i turn the louder the noise gets. It sounds like the posi unit but I'm not sure. And this only happens when making right turns while the car is decelerating. Does anyone know whats happening or how to fix it?? Any help or comments would be great!!
Old Nov 21, 2009 | 08:10 AM
Did you use the GM LSD additive when you filled it back up?
Old Nov 21, 2009 | 09:44 AM
pboxfun's Avatar
Yes, i did put in the GM LSD additive when i put it back together.
Does anyone else have any other ideas??
TitoPR221
Jan 29, 2015 08:00 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
Christopher
Sep 14, 2002 03:08 AM
