Pressure Plate bolts
Old Jul 13, 2006 | 08:27 PM
CamaroBoy96Z28's Avatar
Anyone know if the Gen I PP bolts are the same as the LT1s? They should be but I need to know for sure. Looking to order the ARP PP bolt kit from Summit. Looking at p/n ARP-130-2201.
Old Jul 15, 2006 | 02:49 AM
Sleeper_Z's Avatar
Re: Pressure Plate bolts
I dont belive they are the same. LT1s use an odd bolt that has about 3/4-1" of threadless shank then about 1/2" of threads on the end. You might want to just contact a GM dealer and buy original GM pressure plate bolts.
Jeremy
Old Jul 15, 2006 | 10:01 AM
Thanks. Just wanted to be sure.
Old Jul 15, 2006 | 10:08 AM
Jazsun's Avatar
Are you suppose to replace the PP bolts if you are switchin out PP's?
Old Jul 15, 2006 | 10:23 AM
You dont have to. Its recommended for flywheels, but not really necessary either.
Old Jul 15, 2006 | 07:43 PM
Sleeper_Z's Avatar
CamaroBoy96Z28, No problem man. Good luck with your clutch swap.
Jeremy
Old Sep 17, 2006 | 06:20 AM
Live for TAs's Avatar
Found a possible part # of 10079898 if anyone can confirm this. This was from a writeup of a guy using a LT1 F-body flywheel in a Vette with a LT4 pressure plate, so it seems like the bolts should be the same. Couldn't find the part # on Shoebox or any other online source yet.
It sucks that ARP doesn't make them.
EDIT
Confirmed the PN at Gilbert Chevrolet with a pic:
Old Sep 17, 2006 | 04:31 PM
Excellent find. This should help anyone greatly if they need to find these bolts for whatever reason.
Old Sep 19, 2006 | 06:32 PM
The #1 (IMHO) GM Parts vendor, Dal Slabaugh, has advised he has 24 of these on NATIONAL BACKORDER as of 9-18! Sounds like they may be on their way to being phased out.
I found a possible alternative here at McMaster-Carr (kind of a playground for all sorts of fabrication, they had an odd sized fuel safe hose I needed for the 280Z fuel tank) :
Item # 92316A630, 3/8-16 grade 8 long shoulder bolt, 9/16" socket 13/16" flange head, 1&3/4" long. I measured the stock bolts and found they were 1&5/8" long with a 1&1/8" shoulder with a 3/4" flange. I also ordered some of the flange bolts in 2&1/4" length in case I need to cut the threaded part down.
I'll update after they arrive.
EDIT
I got both sets of bolts. The 1&3/4 are about the same length as the stock ones, but the shoulder is a good bit shorter. The 2&1/4 ones have the same shoulder length but the threaded part is of course longer. Looks like it will still fit in the flywheel threaded part OK.
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
