Pressure Plate???
Old Dec 12, 2004 | 09:42 PM
Heatmaker's Avatar
Advanced Member
Pressure Plate???
Is it possible to refreshin a pressure plate? when swapping disk? or is it best to buy a new one all together???
Old Dec 12, 2004 | 11:27 PM
GreenDemon's Avatar
Re: Pressure Plate???
It's best to buy a new one. The pressure plate uses spring tension to hold the clutch disk tight to the flywheel. Over time the springs get weaker and could start causing slippage in a performance environment.
Old Dec 12, 2004 | 11:37 PM
Heatmaker's Avatar
Advanced Member
I see... just being cheap... My SLP PP has less than 15K on it... just like my SPEC clutch... that needs to come out.
Old Dec 13, 2004 | 09:03 AM
GREGG 97Z's Avatar
I reused my SLP PP when I switched over to a SPEC 4 disc. The SLP clutch/PP had less than 10k on it and wasnt slipping or anyting, I just wanted to upgrade to the SPEC disc. I had my stock flywheel resurfaced and cleaned up the face of the PP with a mouse sander (dont laugh, it worked good) and a 120 grit sanding pad. It wasnt grooved or anything, I just took the haze of it with the sander. Worked very well and the new clutch is grabbing fine so far. It probably is best to replace the PP at the same time, but I was being cheap too
Old Dec 14, 2004 | 03:34 AM
GreenDemon's Avatar
If you have low miles on it, you might be able to get away with it. Just remember that different pressure plates might have different spring rates/forces, and that could affect how grabby the whole setup is.
Old Dec 14, 2004 | 10:38 AM
Heatmaker's Avatar
Advanced Member
ah... I see.... guyess I'll buy a new PP... but then again... might as well as get the ST... and call it a wrap... sell the FLywheel.. and the clutch and but that cash towards the real deal.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
ducttape1975
Jul 10, 2015 06:29 PM
