Pressure bleeding the slave cylinder.
Old Apr 14, 2006 | 04:35 PM
supercharged87's Avatar
I just bought a new McLeod street twin, and a new GM slave cylinder/master cylinder set up. I took the GM master cylinder off and put the Mcleod one on that came with the clutch. I want to bleed it before I put it in, Mcleod recommends pressure bleeding the system. My two questions are this, what is the procedure for pressure bleeding this set up, and whats a decent tool to use, a Mityvac pump?
Old Apr 17, 2006 | 08:29 PM
Re: Pressure bleeding the slave cylinder.
Anyone? How did everyone else bleed their clutch when they put in a Mcleod Street Twin?
Old Apr 20, 2006 | 07:23 PM
QUASARBLUEZ28's Avatar
I had the whole system out when I did mine. Filled up the resevour and worked the slave cylinder rod a few minutes then the master cylinder. Added more fluid as needed and did it again. I kept the components in their relative positions as they would be installed.
RES on top then Master cyl with the slave being lowest. Worked just fine .
Old Apr 22, 2006 | 11:28 AM
I have it i the car right now, but it should still work the same. Did the air escape out the res.? Just wondering because there's no bleeder.
Old Apr 23, 2006 | 06:39 PM
Yes it will bleed out of the Res.Keep the cap off. You'll see a steady stream W/O air when its purged.
Rod Bender
Nov 7, 2023 02:30 PM
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
supercharged94Z28
Jun 2, 2015 03:32 PM
