Powertrax No-Slip Traction System
Old Aug 31, 2005 | 11:19 PM
Nasty350LT1's Avatar
Lightbulb Powertrax No-Slip Traction System
Anyone here try this.
I understand it really beefs up the strength of the rear-end.
Get locker-equiped traction with limited slip smoothness!
The Powertrax No-Slip Traction Systems are the latest design in traction-adding differential technology. They combine the smooth operation of a limited-slip differential with the traction performance of a locking differential. A precise synchronization mechanism eliminates the ratcheting sounds typical of other locking differentials. Special gear and spring designs reduce the backlash, and, therefore, the driveline windup. Only ultra-strength material that is 67 percent stronger than titanium is used. Installation is simple because no ring and pinion setup is required. In addition, no special tools or oils are needed. Step-by-step, model-specific instructions are provided with every kit.
Old Sep 8, 2005 | 02:31 AM
Re: Powertrax No-Slip Traction System
Update, Well so nice of everybody to reply with their opinions.
As it turns out "Powertrax" does not make a unit for my 1992
Z-28. Powertrax has one for every other year but mine...
So, I just saved myself $400... Good Deal.
I guess, I'll just go with the "Detroit Locker"
Old Sep 8, 2005 | 05:03 AM
rskrause's Avatar
Moderator
You might have gotten more info if you had posted in the correct forum (Drivetrain).
Rich
Old Sep 8, 2005 | 06:37 AM
Shockwave's Avatar
Lounge Moderator
Moving to Drivetrain forum...
Old Sep 8, 2005 | 06:00 PM
Josh'95Z28conv's Avatar
Unless you're going to have a ton of power, and rarely drive on the street, I wouldnt recommend a locker...
Old Sep 9, 2005 | 11:30 AM
curtSr's Avatar
I tried the powertrax in my TR7 conversion. Initially the 10 bolt chevy rearend was behind a beefed up 305 and T5 transmission. I liked the way it worked. It wasn't to noisy, and it did perform as I expected. However, when I transplanted a cam and heads LT1 and T56 combination into my TR7, the powertrax couldn't hold up to the power. The teeth rounded where the engagement action occurs, and I was getting a loud clunk as the teeth tried to seat with one another. I believe the documents for the powertrax indicate that it is fine for stock applications and stock replacement. In my case, it just didn't hold up. Even though I didn't have many miles on the powertrax, the time of warranty had expired, so they didn't want to send a replacement. I am now looking for another solution to my no-slip or limited slip needs. I hope this helps.
Curt Sr
Old Sep 9, 2005 | 01:02 PM
rskrause's Avatar
Moderator
I have been happy with the Eaton posi, but my car is a street car that goes to the track and my priorities are good manners in fast street driving. Nonetheless, I get consistent low 1.5's in the 60' at the track and it launches straight and hard.
Rich
Old Sep 9, 2005 | 01:11 PM
curtSr's Avatar
Rich,
Thanks for that info. I too have street manners as my top priority. I will look at the eaton posi.
Curt Sr
Rod Bender
Nov 7, 2023 02:30 PM
Javi Fierros
Jun 10, 2015 03:35 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
