Post your A4 to M6 conversion experience
Old Mar 1, 2007 | 10:39 AM
CrazyLT1's Avatar
Hey guys,
Looking to convert over from an auto to 6-speed in my '97 camaro LT1. I already found the kit I am buying from someone on this board.
Just wondering if some people would share their experiences with the install. Such as: how long did it take to do everything?, what is the most difficult part?, or any other hints or insights you wanna give....
thanx a lot in advance....
Old Mar 1, 2007 | 10:47 AM
Capn Pete's Avatar
Read my comments in this thread (I'm not typing all that again!! )
Also, try searching this forum for keywords "swap" and/or "conversion" ... you should find lots of info . General concensus is A4 --> M6 = good .
Old Mar 1, 2007 | 10:49 AM
CrazyLT1's Avatar
Will I need a new driveshaft due to the 6-speed tranny being longer?
Old Mar 1, 2007 | 01:01 PM
hotrod18_69's Avatar
You keep the same driveshaft.
Went very smooth for me.. Took about 11-12 hours taking my time.
Shoot me a PM or e-mail hotrod18_69@yahoo.com with a list or pic of everything you got. I'll make sure you got it all.. And if ya have any other questions.. I can help you though it..
Old Mar 1, 2007 | 01:40 PM
CrazyLT1's Avatar
OK cool thanx a lot!! I am going to pick up everything soon & will let you know so we can make sure I have everything.
I was gonna take it to a shop and have them do it. But after searching I see that it shouldn't be too much of a pain to do myself.
Old Mar 1, 2007 | 02:03 PM
arcticz28the383's Avatar
Pedals are probably the worst part. Other than that, getting all the right parts is most of the battle, just do a lot of research and you'll be fine.
Old Mar 2, 2007 | 07:50 AM
Capn Pete's Avatar
Everybody complains about the pedals!! I actually found that one of the "easier" parts? Getting the master cylinder in was harder!
Old Mar 2, 2007 | 11:26 AM
PipesTA's Avatar
It's not as bad as you think really. I swapped mine in, in about 3 days taking my time. I had got EVERYTHING needed to swap over. The guy I purchased the parts from was kind enough to label every nut and bolt when he was disassembling his car. Here's a good site to check out for the swap. This is the write-up I followed: http://www.afrashteh.com/tranny_pics/T56.htm
Old Mar 2, 2007 | 01:13 PM
bond2's Avatar
I've been wanting to do this for years, but the task just seems daunting. Does anyone have a complete list with actual GM part numbers? Did most of you get used T56 trannies or go for a new one?
Old Mar 2, 2007 | 01:29 PM
PipesTA's Avatar
^^^ It's really not as bad as you think. Just take your time. I purchased my parts used. (Previous owner was going T400) Got everything I needed w/ a Spec Stage 2 for 1200.
Old Mar 4, 2007 | 10:06 PM
redcamaroz28's Avatar
I did this about a year and a half ago. It took me and my friend a day to do. There wasn't anything extremely challenging with the swap. The only thing that was difficult was making sure the hole I had to cut in the firewall was in the correct spot for the Clutch master cylinder.
Old Mar 5, 2007 | 07:00 AM
Capn Pete's Avatar
Just use the M6 pedals as your template!!! EASY!!!
Old Mar 5, 2007 | 08:26 AM
MEAN LT1's Avatar
Once i got all the part it didnt it took about two days working on and off on it. Like the others said, doing the pedals was the worst part. as far the were to drill the hold for the m/c If you flip the rug expsoing the rubber mat underneth, there is a template for you to drill through. Some people removed there steering wheel for more room and some dont. I did and it made putting the pedals in that much easier. I aslo removed my drivers seat and found at least five dollors in change from over the years. Good luck!
Old Mar 6, 2007 | 10:04 AM
97pontta's Avatar
The swap isn't bad at all. I did it myself in two days working off and on at it. I pulled the steering column which made the pedals easy. For me mounting the McLeod M/C was the hardest part, two sets of hands would have made it much easier. I used the same guide as posted above and has all the part numbers for the wiring components you need for the swap. I found a used tranny and all the parts for a good price. I did find that I was missing the inspection cover and GM no longer has that part available so I made one from 1/8 thick aluminum.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 12, 2014 10:51 PM
