Post about clutches
Old Dec 27, 2003 | 05:59 PM
AustinZ28's Avatar
Post about clutches
I posted this in the drivetrain forum and nobody replied, does anyone know the answer?
I found Clutch kits at O'reilys, Adavanced auto parts, and AutoZone.
Do all these carry the Lt4 PP in their clutch packages? I know the Autozone PP is an lt4, but what about O'reilys and Adavanced? I'm asking b/c the Autozone clutch kit is about $279 whereas the other to stores have it for around $195. -Thanks- Brad
Old Dec 27, 2003 | 11:52 PM
my94blackz's Avatar
do not run a zoom clutch wow do they suck.
Old Dec 28, 2003 | 12:08 AM
97WS6SCharged's Avatar
A cheap clutch is not the way to go. Spend the extra $$ and get a nice Spec or a Centerforce or a Ram clutch. You'll be alot happier.
Old Dec 28, 2003 | 12:09 PM
AustinZ28's Avatar
They all have the same Pressure Plate though. Valeo has a patent on them. SLP is the Valeo with holes in it. One of the other aftermarket clutches is the Valeo with weights on it. I just want the Lt4 pressure plate, throwout bearing and alignment tool. Them I'm going to use a McCloud 7500 rpm performance disc. -Brad
Old Dec 28, 2003 | 01:11 PM
zx1216's Avatar
you can get the lt4 pp on gmpartsdirect for $204, the part number is 10222083, btw i'm gona run the same setup as you are planing to in a few weeks.
Old Dec 28, 2003 | 01:46 PM
FormulaLT1Power's Avatar
Spend the extra money and get a CenterForce. I had problems with clutches and tried some of the cheapos! After my 2nd replacement clutch I decided to buy a good one. Never had to worry about that again. The CenterForce grabs like no other also! I bought the CenterForce Dual Friction for around $520? from Summit. I just yanked the motor out and checked on the clutch...not even worn out! By far the best clutch I've ever seen!
CenterForce
Old Dec 28, 2003 | 04:50 PM
zjet's Avatar
i am going to put a new clutch in this spring.(broke my centerforce on the dyno,they suck),i am going to get the autozone kit and by a mccleod disk,the pp in the autozone kit is a brand pp same disk you will buy from a dealership or gmpd.
Old Jun 23, 2005 | 12:15 AM
blackztpi's Avatar
Re: Post about clutches
so you are saying to buy the pressure plate from the auto store and then choose whichever disk u choose?
Old Jun 23, 2005 | 05:40 AM
96trans am's Avatar
Do NOT go with a SPEC clutch. I have the stage 3 and geez that thing sucks sooo bad. I am going to agree and say dont go cheap on this one, you may regret it. If you can, go with a Mccleod. Thats all i hear everyone recommending. Never heard anyone talk bad about them, which doesnt happen to often. Lets see if someone chimes in disagrees, and says there ****.
Old Jun 23, 2005 | 08:06 AM
89385formula's Avatar
Ummm, what's your basis for saying that SPEC sucks..maybe you just can't drive? I have a SPEC stage 3, and it works great..grabs better than the old centerforce Dual Friction I had. McCleod Street twins is what everybody talks about not the single disc ones. I also wouldn't cheap out on a clutch...its too much work to do it again...just do it right the first time. If I had more money, i would have went ahead and got the McCleod street twin. But I am very happy with my SPEC and I know plenty of others that love em. I don't think there is any problem doing what he wants to do....I bet it would be a very good clutch, and certainly not cheap.
Old Jun 23, 2005 | 08:16 AM
RocCityZman's Avatar
Austin - based on the mods in your sig I don't think you'll see any gains or benefit from an aftermarket set up. I researched this a few years ago and ended up going with an OEM set up from SLP & gmpartsdirect. Unless you're approaching 350-400 I think a street twin, SPEC 3, or the like is overkill. I definitely woul dnot do anything less than OEM though. As someone stated, it's too much work to do it twice.
Again, that's just what I picked up from a few searches on here.
Old Jun 23, 2005 | 09:43 AM
There's nothing wrong with the Spec 3 clutch. Mine held up to well over 400 rwhp on a daily basis for over 40k miles, and it's still going strong on the same (detuned) motor. You wouldn't know it wasn't stock unless I told you. There's also nothing wrong with the street twin either, but if you don't need a clutch to handle 1200 hp, why spend twice the money?
Old Jun 23, 2005 | 10:31 AM
Originally Posted by RocCityZman
Austin - based on the mods ......
Do you realize that you responded to a post that is almost 1.5 years old, by someone who has not posted on these forums since 6/2004?
Not sure why people resurect these old posts
Old Jun 23, 2005 | 10:39 AM
hahahahaha..LOL I didn't even think about looking at that. WOW, I feel dumb.
MyfateZ28
Jun 19, 2015 03:42 AM
blkWidow
Apr 21, 2015 01:56 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
