transmission jack adapter ?
Old Jun 22, 2005 | 01:49 PM
sabre81's Avatar
anyone have one of these guys? Does it work ok? I just did a t56 swap and it was a HUGE pita to install it with a normal jack.
heres one, expensive, but just an example...
http://www.shopperschoice.com/item_item_370687.html
thanks
Old Jun 23, 2005 | 10:40 AM
G. McDonald's Avatar
Re: transmission jack adapter ?
I just made one out of a piece of plywood with 2 2"X2" pieces of wood attched along each side to prevent the tranny from rolling off. Once I jacked up the jack under the tranny I just held the tranny on with a come-along strap. It worked quite nicely and did not take long to make. I bolted the tranny cradle to my jack with a single bolt after removing the standard jacking pad that comes with the jack. I hope that makes sense.
Old Jun 23, 2005 | 10:54 AM
OBE1 95Z28's Avatar
Harbor Freight sells an inexpensive tranny jack that includes a mounting strap. This in not an adaptor, it's the entire jack that works well for the T56 and automatics.
ryanhilsgen
9
Sep 21, 2015 07:34 PM
raroz28
Sep 8, 2015 06:10 AM
Cam's maro
Aug 11, 2015 07:45 AM
whitehooptie
Jul 22, 2015 10:25 PM
whitehooptie
Jul 12, 2015 06:10 PM
