Pinion seal leak repair
How much would it cost for the dealership to do a pinion seal repair? How much for somewhere else to do it? I know its possible to do yourself, however, I have never done anything rear end related so I have no experience in that area.
The dealership charged me a few hundred dollars to do the repair. I cant remember the exact figure (this was 4+ years ago) but it was a lot and a complete rip-off. If you HAVE to, go to a reputable shop. I'd imagine prices anywhere else would easily be less than a dealership of any sort.
i charge 1 hours labor, pinion seal, depending on the mileage i would recommend replacing the diff fluid so add another 1/2 hour and two quarts of fully synthetic fluid. cheapest $70. most expensive $125. dealerships around here is $200 for the cheapest
you probly have a grooved flange or the pinion bearings are bad,, a pinion seal can be done without tearing down the complete rear end but extreme care must be taken to get the pinion bearing pre-load back to where it was, if your pinion seal has been replaced that many times i would bet that the pinion bearing pre-load is not correct now and the pinion crush sleeve is crushed more than it should be putting strain on the bearings and wearing out your seal
kev93z28
Aug 19, 2002 12:48 AM
Aug 11, 2002 02:24 PM
RobertoZ28
Jun 16, 2002 02:04 PM
