Need a rear end for my 96Z28
Old Jul 3, 2002 | 09:10 PM
Super96Z28's Avatar
Post Need a rear end for my 96Z28
Hi,
The dealer screwed me and just replaced the pinion seal (when it was under warranty) and tightened the pinion so much it fried the pinion bearing. They replaced that (under dealer warranty) and I thought all was well and then the pinion started leaking like crazy and now they say my case is cracked...I am p*ssed. My car is now out of warranty and they refuse to fix it even though they knew it was bad while it was under warranty.
Now, does anyone know of a good place I can get a complete rear end for my car for a decent price(Under $300-400)?
And does anyone know if it is easy to put a 99 up rear in the car since it has a torsen diff? Is it compatible with my ABS and traction control? I have a 96Z28.
Thanks,
James
96 Z28, A4, White, T-Tops, Tan Leather, ASR, 3.73 gears, SLP 2-on-d-left, K&N cold air, throttle blade, power programmed.
89 TTA, boost is good.
Old Jul 4, 2002 | 07:12 AM
Speedy Dragon's Avatar
Post
Not sure about the price but Rear ends aren't all that hard to put in. A couple of bolts and stuff...The gears are a different story. Go to a junk yard I am sure they have one...O not all rear ends come with the abs in the back just for fare warning.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
