people with 2800 stall
Old Jan 18, 2007 | 10:15 PM
ajlew9428's Avatar
I want honesty here. Did you notice a signifigant decrease in gas mileage after you installed your 2800. Can you feel a pretty big difference in the driveability over stock? In your opinion, was your car more fun as a dd to drive before, or after the stall? thanks
Old Jan 19, 2007 | 02:04 AM
Performabuilt's Avatar
Supporting Vendor
I have done the 3500 stall in a 9.5 one of ours and I like it tight converters still feel quite decent at light throttle . cruising no difference due to lock up , launch change amazing and fuel efficiency at low speeds slightly lower but not real bad.
A converter can really wake the car up! best investment you can make really for more GO!
Old Jan 19, 2007 | 09:26 AM
nodnarb481's Avatar
i really havent noticed a change in gas mileage at all and I ONLY drive city except for a few rare occasions that I actually have somewhere to go. It may have dropped 1mpg
Old Jan 19, 2007 | 09:33 AM
Supporting Vendor
depending on your driving habits the loss may would be quite small, Particularly if you a quick launcher , I know some people try to take off easy with hihr stalls and stay in stall to long and that will eat the fuel up quick .
Old Jan 19, 2007 | 11:42 AM
Z-RATED94's Avatar
Kind of depends on how much city driving you do too. Don't forget the converter locks up at about 42 mph, so after that it really doesn't matter. That is if you are still running a lockup converter. And don't forget, what rear gear you have helps determine what the new converter feels like and or gas mileage.
Old Jan 20, 2007 | 01:03 AM
Supporting Vendor
very true and as i said how you accelerate strangley quicker is good in this instance
Old Jan 20, 2007 | 09:29 AM
12SCNDZ's Avatar
With my 3200 stall lock-up converter, I was getting between 16-18 MPG with a 12.0 second, ported head, CC305 car. Once a stall converter goes into lock-up, it will get the same fuel economy as a stock stall converter, because it stops slipping/stalling.
Frank
CPT
Old Jan 20, 2007 | 10:59 AM
ajlew9428's Avatar
Thanks for all the responses. Looks like a stall is coming soon. Ill probably wait till the tranny goes, before I get it though
Nayr
Mar 3, 2023 08:34 PM
generaldave
Sep 25, 2015 06:48 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
