Paddle Shifters is it possible on an 1995 Camaro z82?
Old Mar 22, 2010 | 03:03 PM
rhodesz09's Avatar
i am in kind of in a bundle with this one i have a 1995 camaro Z28 with 75,000 on it and am trying to figure out if it is possible to install paddle shifter into in even tho it does not have tiptronic? is it possible to do and where would i be able to do so?
Old Mar 23, 2010 | 01:43 PM
97FormulaWS-6's Avatar
Is it an automatic or manual transmission?
If it's a manual then no; if it's an automatic then something custom could be fabbed.
There is no bolt-on kit.
Old Mar 23, 2010 | 01:58 PM
BloodyZ28's Avatar
i remember reading an article on this a while back, where paddle shifters were added into a 3rd gen. It looked fairly simple to install, and all it really did was imitate the shifter moving (moving the shift linkage) when you pressed the paddles. there was a unit which replaced the shifter assembly with a computer controlled box, connected to the paddles.
The problem is if you installed this on a 4L60e, the lag would probably be too annoying to use comfortably. If you've even tried bump-shifting the auto, you know about the pause between when you move the shifter, and when the trans shifting gears "manually"
If you reprogrammed it so the trans shifted quicker AND installed a paddle shift kit you could probably get it done nicely though
Jlo
Feb 3, 2015 09:41 PM
Jan 5, 2015 07:14 PM
joe777107
Dec 1, 2014 09:32 AM
SLIMJIM
Jan 7, 2003 11:06 AM
Chrisdude
Jul 24, 2002 02:25 PM
