no reverse
Old May 14, 2009 | 08:18 PM
LearJet's Avatar
no reverse
A buddy of mine has a '60E in his truck and he lost reverse. when I asked if the check engine light was on he said it's been on for a few years. I haven't been to the truck to scan for codes yet but he told me this: Shifts through al forward gears when selector is in O/D. Will not go into manual 1st or second, he wasn't sure about D but he thinks it works, no reverse at all. Any ideas?
Old May 14, 2009 | 09:02 PM
Performabuilt's Avatar
Supporting Vendor
No reverse is a purley mechanical issue. (reverse input drum/low reverse clutch set) If he also didnt have second or 4th could be the sunshell spripped which will also cause a no reverse, But in all cases trans is gotta come out be replaced or rebuilt. Afraid theres no code for that.
Frank at PerformaBuilt
Old May 15, 2009 | 08:08 AM
LearJet's Avatar
could the manual valve be hung up or something? It's mechanically linked to the shift selector correct? Perhaps the linkage fell off? Just thinking out loud. I'm guessing I will be pulling the pan off soon and will know more then.
Old May 15, 2009 | 08:28 AM
Supporting Vendor
I think if the manaul linkage was off you would always be stuck in one particular gear position.
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
Beave2780
Jul 7, 2015 06:36 AM
jimlab
Oct 6, 2002 08:37 AM
