New rear gear...computer ok?
In a few weeks ill be putting Motive 3.42 gears in the rear, replacing the 3.23's that are in there now. The rear was howling pretty good so I decided to give the rear an overhaul and there was no difference in price between the 3.23's and 3.42's so I opted for the slightly better performance, although im not expecting much of a difference. Anyways, any need for a computer tune to get the car to think everything is normal?
Alright, thats what I figured, just something small. The computer will be geting re-tuned later in the summer, itll just be a few weeks itll be off. I was mainly worried about the trans freaking out or something.
Yeah, re-program for the correct gear ratio and everything will be 100%
Since you're not switching drastically between ratios, I think you'll be ok, but I've heard that when going extreme (say from 2.73's up to 3.73's/4.10's) that the computer (which controls both upshifts and downshifts) should be re-programmed before ragging on the car, because the tranny may have odd shifts/shift-points, because the speed ramps up much quicker, and the computer may allow shifts to occur when/where they shouldn't
. You can still DRIVE the car (I have myself) but from what I've heard, it's not recommended to drive it too aggressively, which I never have until I've re-programmed for the gears.
Like I said though, since you're only going from 3.23 --> 3.42, that's probably not a big deal ... try it out and see
. You can still DRIVE the car (I have myself) but from what I've heard, it's not recommended to drive it too aggressively, which I never have until I've re-programmed for the gears.Like I said though, since you're only going from 3.23 --> 3.42, that's probably not a big deal ... try it out and see
carguyshu
Jan 22, 2017 11:19 AM
96SilverRam
Nov 20, 2016 11:19 AM
BLK1997Z28
May 1, 2015 12:23 PM
