4000 or 4400 stall?????
Old May 3, 2005 | 10:55 PM
gabez28's Avatar
Ok here's the deal I currently have a Vigilante 3200 stall converter, but I wanna go bigger. My current mods are LT's,1.6rr's, 227/233 112lsa cam, 30# injectors,3.23 gears( which are being upgraded to 3.73 at the same time as the converter) and a few suspension goodies. Im on a stock 10 bolt( yeah I know it wont last ) but I consistently cut 1.8x's 60' with et streets.
Now Im going with an Edge Converter and I can get whatever stall I want. So since Im going with a 4000 stall is a 4400 to big for my car at its current stage. Im gonna eventually get some heads later this year to go with the cam but for now this is all I got.
Oh yeah I've ran a 8.2 @ 88.9 mph in the 1/8 with that setup above.
Old May 3, 2005 | 11:03 PM
madwolf's Avatar
Re: 4000 or 4400 stall?????
You're probably going to have shifting issues with that stall. I would go with some 3.73s or 4.10s instead.
Old May 3, 2005 | 11:04 PM
neil350's Avatar
I would get P.I to restall the Vigi to like a 3800.
Old May 3, 2005 | 11:11 PM
gabez28's Avatar
Sorry forgot to add I have a pcm4less tune set to my current setup and when I get the new converter in I'll be getting another tune to current the shift points.
Old May 3, 2005 | 11:13 PM
madwolf's Avatar
It's not the shift points, but the high stall issue. With that big of a stall, you're almost guaranteed to have it.
Old May 3, 2005 | 11:15 PM
gabez28's Avatar
What issue is that. Sorry Im a little slow.
madwolf's Avatar
It won't shift from 1st to 2nd at WOT with good traction.
Old May 3, 2005 | 11:19 PM
gabez28's Avatar
Are you referring to the "stall wall" commonly found in ob1 LT1's with a higher stall. If so I had that problem with my 3200 and had it fixed with another tune by pcm4less.
Old May 3, 2005 | 11:46 PM
gabez28's Avatar
Ok looking at my dyno chart my peak torque is right at 4000 rpm which 333 ft./lbs. So I think the 4000 would be the best fit for my car right now.
Old May 4, 2005 | 12:49 AM
96m6lt1's Avatar
i would not go higher than 3800 with the cam you have and the gear ratio you have would not be enough,most cams from 230-244 require a stall speed of 3500 w/4.10-4.56 gear.if it was me i would get more gear first the stall you have now is sufficient...............
Old May 4, 2005 | 01:31 AM
1982z28with18s's Avatar
Yet again I get to read posts like this that don't make sense. A 4.56 gear would KILL him at the 1/4 mile track since he'd be hitting OD at about the 1000ft mark. Gear selection should be made based on tire height and mph in the 1/4 mile, you want to cross traps at the top of your 1:1 gear for an ideal setup.
Also, don't forget to consider the different STR's of a particular stall.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
