New 3:73's = whine
Old Aug 7, 2008 | 01:46 PM
LexLT1-Z28's Avatar
New 3:73's = whine
Got my new Motive 3:73's installed, took 2 weeks at the speed shop. He said they had it apart 3 times to get it just right. Drove it home 10 miles, whines when you let off the gas and even steady driving around the 40 to 50 mph mark. I bought Motives as I heard they are supposed to be quiet. I called the shop up and they said they had called Motive and they told them that they have to be broken in and then will quiet down. 30 Minutes then cool and then another 30 minutes of driving should do it. My regular mechanic who doesn't do rears thinks the pinion bearing is not set right and that the first time at the track I might blow the rear. The speed shop swears "the rear is set up 100% right on." Any opinions as I want to take it to the track the first cool day they are open.
Old Aug 7, 2008 | 08:47 PM
If it was set up right, it would not whine. I disagree with what they said about break-in. If they whine now and you keep driving it, they will wear into that pattern and never be able to have the whine adjusted out. Setting up gears can take a lot of trial an error.
Old Aug 8, 2008 | 10:56 AM
Z-RATED94's Avatar
What shoebox said. The break in period has nothing to do with the whine. I have Motives too, they make very little noise on decel.
Old Aug 8, 2008 | 01:23 PM
slomarao's Avatar
+2, i have GM motives in mine with a eaton diff. You cant even tell theres a gear in my car. I also have a alum ds. which helps out. But accel, decel, whatever you cant hear or feel **** from my car.
The install is everything with gear whine. Go back or find somewhere thats knows what they are talking about. They didnt do it properly. They do break in but shouldnt be making all that noise/whine.
Old Aug 11, 2008 | 08:02 AM
onebadponcho's Avatar
It depends on which Motives you bought. If you got the same ones I got for my 10 bolt (which were Motives cut in Italy), then they're going to make a little noise - not obnoxious noise, but some noise. I got my gears from DTS and they even told me they'd make some noise. I had 2 separate shops set my gear up because after the 1st, they seemed too noisy. The 2nd shop (Randy's Ring and Pinion), got it set up where it was quieter, but it still made some noise. There's A LOT more factors other than gear setup that determine whether or not they're going to make noise.
Old Aug 12, 2008 | 01:59 PM
LexLT1-Z28's Avatar
Did the break in procedure and they still make the whine. I've put about 200 miles on them. Going to get a 2nd opinion from another shop tomorrow. I just don't want this rear to blow up as I just got laid off from work. Me and 200 other co-workers
Old Aug 12, 2008 | 07:35 PM
OK, how loud is the noise? Obnoxious to the point you can't hear the person next to you talking?
Also, if you're that concerned about scattering your rear, it might be wise not to take it to the track.
Old Aug 13, 2008 | 07:18 AM
LexLT1-Z28's Avatar
With the windows up at 60mph you can't hear it. At 40 to 50mph especially letting off the gas and coasting very noticeable.
Old Aug 13, 2008 | 08:08 AM
rskrause's Avatar
Moderator
It is very hard to set a rear end up properly - factory quiet is almost never achieved on the first attempt, if ever. Pretty much, I'd say live with it if you can. I'd like to know how the factory does it - there must be some tricks involved.
Rich
Old Aug 14, 2008 | 08:24 AM
LexLT1-Z28's Avatar
Got the 2nd opinion and he advised it won't last. Took it back to the shop, wine getting worse as you can hear it with the windows up when you coast at 50mph. They agreed to replace the gears next tuesday.
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
nd4spd200
Aug 21, 2015 09:30 AM
alphaauto
Jul 26, 2015 04:40 PM
mrwz28
Jul 8, 2015 09:11 PM
