need a new flexplate
Old Jul 12, 2007 | 11:48 AM
Soccerbum21's Avatar
after reading some of the threads i found in a search, i have these questions
i need a new flexplate
questions.
1. Do i need to get an internal or external balanced flexplate?
2. What brand do i need for my setup (I/H/E, stall, built trans and 125 shot)?
3. Why is hte GM performance parts one in Jeg's have a 10.75" bolt pattern and the TCI has a 10.5" bolt pattern for the converter?
thanks!!!
Old Jul 12, 2007 | 04:11 PM
Purplemaroz28's Avatar
questions.
thanks!!!
1.Depends on your engine. if it is stock get the external balanced flex plate, if it is a modified bottom end, ask ur machinist.( i know this is true for m6 not sure about a4s)
2. Im going to guess that I/H/E is intake/head/exhaust, intake: any aftermarket bigger name company will do e.g. moroso, k&n, slp, etc. and they are all around the same price. head: U can have ur heads ported by lloyd elliot who i would recomend after he did my head cam and combo, and with the better flowing heads you want a cam to get the most out of it. check his website out at http://www.eportworks.com
as for exhuast, since u are going to be spraying, set of 1-3/4 longtubes would be best(when spraying u want bigger exhaust) i would recomend pacesetters, there is usually a sale going on, but if u have to deal with emissions or bumpy roads, u might consider the mac mid lengths. most of the catbacks flow about the same, i have slp lm, a little to loud imo ( i do have headers and !cat though), i want to change out to a borla muffler and see how it sounds.
3. are u looking at the bolt pattern or the size of the converter?
hope this helps
steven
Old Jul 12, 2007 | 05:20 PM
haha, thanks for the input but i think you mis-interpreted my post
i HAVE intake/headers/exhaust on my car. my flexplate on the car now has been bent by a bad torque converter install and i need to get a new one. the torque converter is under warranty so that'll be free. i was asking what brand of flexplate i need.
basically i need to know if i need a internally or externally balanced flexplate. the motor is a stock rebuilt unit so i'm assuming it's internally balanced. per factory specs.
anyone shed any light on this?
Old Jul 12, 2007 | 07:22 PM
12SCNDZ's Avatar
Jegs sells an externally balanced 153 tooth flexplate that works on our LT1's. It's less expensive than any other I've found. It's SFI approved, and costs less than a stock GM plate. It's part number 555-60-153, and it sells for $56.99.
Frank
CPT
Old Jul 12, 2007 | 08:07 PM
LT-x7's Avatar
Frank
CPT
That's the one I run also.
Old Jul 13, 2007 | 10:00 AM
did you have to get it machined to put it in balance? or just bolt it on there and let it ride?
Old Jul 13, 2007 | 11:47 AM
12SCNDZ's Avatar
You should never have to machine a flexplate.
Frank
CPT
Old Jul 13, 2007 | 04:43 PM
gotcha, thanks!!!
RUENUF
Mar 13, 2016 03:37 PM
alphaauto
Jul 26, 2015 04:40 PM
vodoo-chile
Nov 13, 2003 01:31 PM
vodoo-chile
Nov 11, 2003 08:56 AM
Nostang 96z
Sep 15, 2002 10:15 PM
