Need help with clutch/flywheel options
Old Nov 9, 2004 | 07:21 PM
FRMUL8D's Avatar
I've got a 95 Formula with a stock clutch that I think is on it's last leg.
I called to a local shop today and got a couple of quotes from them for a spec stage 2 and a spec stage 3 hybrid.
My plans are to do longtubes and other bolt-on's in the future and eventually build a 383 for the car, making around 400 rwhp.
They told me my cheaper option would be to resurface the flywheel and put in a spec stage 2.
Then we got to talking about the stage 3 hybrid and they said that if I went with a stronger clutch like that, they would recommend putting in new hydraulics and a new flywheel, as opposed to resurfacing what I have. They said that they would put in new hydraulics because the car has 101K miles on it and with a stiffer clutch requiring more pressure to operate that my stockers may not last very long.
From what they said I don't have to do this all at once necessarily, that the hydraulics can be changed out w/o removing the clutch or transmission.
So right now I am leaning toward getting a stage 3 hybrid and hydraulics from them and putting them in with a friend who's done this before. However I am unsure about the flywheel situation.
Do you guys think that putting in a new flywheel would be beneficial to what I've mentioned above? If so, I would probably put in the spec billet steel model. Also, I know some hate spec and some love them, would my car...being daily driven and probably daily driven for a while after putting a 383 in it, would it be wise to go with the 3 or just try my luck and save my $ with the 2? Any input would be helpful....thanks.
-Ryan
Old Nov 9, 2004 | 08:53 PM
HoustonZ's Avatar
Re: Need help with clutch/flywheel options
I'm in a similar situation. I've been seeing quite a bit of crap about the Stage III breaking. The Stage 1 says highly streetable for up to 400rwhp. I may go with that one.
Old Nov 10, 2004 | 09:41 AM
roguedriver's Avatar
Have you guys looked into McLeod's single disk set up yet?
Ken R.
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 14, 2015 02:02 AM
