need help
Old Apr 19, 2006 | 10:23 PM
formula14.18's Avatar
Question need help
i took my car in and had them in stall my under drive pullyes (march) on my 95 formula and they did not put the stock damper back on and ive been drive it for a couple of months and did not realise it tell i changed my alternator. what should i do
thanks jon
Old Apr 20, 2006 | 07:59 AM
Re: need help
If it is a "sandwich" type pulley, you need to put a stock damper back on.
Old Apr 20, 2006 | 05:14 PM
Re: need help
i bleive it is will it not being on there cause any problems
Old Apr 21, 2006 | 07:18 AM
Re: need help
The damper reduces torsional vibration (cyclic torsional twisting) of the crankshaft. Without the damper the magnitude of the vibrations gets larger. Eventually, the crank metal will fatigue and you run the risk of having it break. How fast that would happen on a "stockish" engine is an unknown. Bottom line.... without the damper the crank is having its life shortened.
