Need Clutch Advice
Old Sep 24, 2004 | 06:28 PM
z28jaz's Avatar
Need Clutch Advice
I need to replace my clutch. I'm not sure what to go with. Needs to be under $400. I have been considering SPEC stage one or the SLP setup. Car is basically stock with intake and exhaust and is a daily driver.
Thanks for the help.
Old Sep 24, 2004 | 09:33 PM
GreenDemon's Avatar
Re: Need Clutch Advice
Go for it. I've never heard any complaints about those, although most people go with Stage 3 or 4. If your stock one worked fine the Stage 1 should be great though.
Old Sep 25, 2004 | 11:43 AM
Loading's Avatar
How much does it usually cost labor wise to replace the clutch?
Old Sep 26, 2004 | 11:48 AM
zx1216's Avatar
not sure on that, prolly more than the clutch itself, i did it by myself with 4 jackstands, a two ton jack and a socket set. It is pretty straight forward if you have the time and somewhere to do it. It is kinda a pain wrestlin the t56 around with out a trany jack but it can be done.
Old Sep 26, 2004 | 02:33 PM
SpeedzAdisease's Avatar
It cost me $325 bucks for labor putting in my clutch and new slave cylinder also got the flywheel machined. Not to bad.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
karpetcm
Aug 14, 2015 03:02 PM
GT what?
Jul 14, 2015 10:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
