my transmission is messing up
Old Aug 26, 2008 | 11:55 AM
jeremy stanke's Avatar
i have a 95 z28 automatic. it has a torque converter and shift kit, it was running fine until last night. before then it would shift hard in first around 2200-2500 when drivinh easy but now it wont shift unless i let off the gas, it seems to be doing this in all the other gears also. it will only shift if i let off on the gas. what would cause this?
Old Aug 26, 2008 | 01:31 PM
Performabuilt's Avatar
Supporting Vendor
Trans may just be tired, But have you checked for codes ? Do you have a check engine light on ?
Old Aug 26, 2008 | 01:42 PM
i scanned it today and it scanned fine except for a o2 sensor. no check engine light
Old Aug 26, 2008 | 02:11 PM
Supporting Vendor
More than likley then the trans is just tired and you are in need of a rebuild or replacement , Please feel free to visit our website and look at what we have to offer you
Frank at PerformaBuilt
www.performabuilt.com
Old Aug 26, 2008 | 04:30 PM
12SCNDZ's Avatar
Jeremy,
I would check the TPS operation first. If you can gain access to a scanner which can watch data, you can see your TPS scrolling up. It should be around .5 Volts at idle, and be near 4.5 Volts at WOT.
What condition is the fluid in? Is it dark, discolored, or have a burnt smell?
If there's anything I can do to help, please feel free to give me a call. 302-250-1202
Frank
CPT
Old Aug 28, 2008 | 07:45 AM
UPDATE- i changed the plugs yesterday because the old ones were fouled from running out of gas. i finally got it started and took it down my road and it shifted fine down the road and back to my house. do you think it is a computer shorting or something?
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
LazyLemming
Aug 29, 2015 07:36 PM
Rittmeister
Aug 7, 2015 01:13 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Boss002
Jul 9, 2015 03:33 PM
