MPH doesnt add up
#17
Originally posted by Robert95z
that sucks... i gained about .35 tenths and 2mph going from 2.73 to 3.73
#18
Originally posted by Capn Pete
C) maybe it's possible that the ignition system is cutting the spark before it actually hits 5700 rpm, thus limiting you to less than the "theoretical" 117 mph??
Just FWIW, my car ran the exact same time and speed as listed in my sig even with 3.73's, as compared to with 2.73's............so if you're running .2 seconds faster than me, 108 - 109 mph sounds more realistic than ~117 anyways.
#19
your car may also have a speed limiter that came on non high speed tire equipped fbodys that shuts down your car like a rev limiter at 109 mine has that on it but you can get it programmed out just a thought
http://www.maysvilleky.net/~gbeard/f...enFAQ/4_7a.htm
#20
when i hooked up my car to datamaster it showed in 3rd gear at 5600 i was only going 107mph and on the calculator i should be at 115... datamaster is probably the most accurate so i dont no what my problem is....converter slip?
NewsBot
09-14-2015 09:20 AM
