moser installed ... but..
Old Nov 22, 2003 | 05:45 PM
camaroz28_97's Avatar
i finished putting in my moser yeaterday everything feels good except when i an going 65-80 and i let off the gas. i get a nasty vibration. i can mostly feel it through the shifter (M6). anyone know what to check???
(PS DS was cut 1/2" 1350 yoke and rebalanced)
Old Nov 24, 2003 | 01:56 PM
new info.
well i did some more test driving and heres what i got:
vibration statrs at ~80Mph and keeps getting worse
vibration goes away MOST of the time when clutch is pushed in or trans is in Nutrual regardless of speed (80+).
there is NO Vibration at any RPMs in any other gear at ANY other speed less than 80Mph.
UMMM HELP
o yea and my SES came on yesterday. i dont know if it has anything to do with this problem
Old Nov 25, 2003 | 07:51 AM
RacinZ's Avatar
Had the same problem when we put a 5spd in a Lincoln LSC, pinion angle was off. When you put the rearend in do you have stock suspension pieces or adjustable ones? Check your driveshaft make sure under load its not going to far forward and into the trans. I mean by that is when under load rear wants to climb up and it pushes the shaft forward and deeper into the trans tailshaft (could be bottoming out inside the trans) not sure if all this will help, but some check points to start. goodluck Andel
Old Nov 25, 2003 | 11:33 AM
how do u set the angles??
i have all stock suspension parts.
Old Nov 25, 2003 | 01:43 PM
tekker's Avatar
ewww ><
adjustable LCA + relocation brackets and an adjustable PHR is win..
and ive read an INSTALL guide or two and i think RacinZ was right.
/tek.
Old Nov 25, 2003 | 02:18 PM
HBHRacing's Avatar
I installed my 12 bolt about 3 days ago and the only problems that I have encountered thus far are a clunking in the rigt rear and DS to long. I will order a custom aulm as soon as I can. Like you I need about a half an inch off. if not pinion angle. Check the tranny mount just to make sure. check the caliper brakets. I had to do some playing around with some shims to get it to clear the rotors. if you find nothing you might want to have the DS rebalenced again....
Old Nov 25, 2003 | 02:23 PM
is there any way to get this to work with the stock TA
Old Dec 11, 2003 | 10:50 AM
TTT
Old Dec 11, 2003 | 01:01 PM
97 RedSS's Avatar
My Moser does the same thing at only 80mph also..Not bad but I can tell there is a vibe..
Cody
Old Dec 11, 2003 | 02:23 PM
no mine is bad
Old Dec 11, 2003 | 04:55 PM
97 RedSS's Avatar
Well mine was very bad because the counter weight on my custom DS had fallen off and it got reallly bad...They didnt weld it on good enough.
Cody
Nov 18, 2023 07:21 PM
Sergio
Jan 27, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
ddr698
Jan 9, 2015 10:05 AM
Redbird
Jul 20, 2002 06:08 AM
