Mcleod S/T install help please
Old Nov 18, 2004 | 11:05 AM
TUFF LT1's Avatar
I put everything together and went to ops check it and got a loud pinging sound. took the tranny back out and found that the clutch pressure plate studs were hitting the slave cyl fork??? Why is this happening and what can I do to fix this? Thanks
Old Nov 18, 2004 | 07:19 PM
TUFF LT1's Avatar
Re: Mcleod S/T install help please
Called Mcleod, guess the studs were 1/8th too long on mine. Ground them down and rest of install went great. Now for the torture 500 mile break in.
Old Nov 18, 2004 | 09:30 PM
TCAL95Z's Avatar
thats not to good.. Did Mcleod use the wrong size studs?
Old Apr 21, 2005 | 04:02 PM
Black_95Formula's Avatar
OMG I have the same prob!!!!! Pissed!
Old Apr 22, 2005 | 07:57 PM
TUFF LT1's Avatar
OK, I don't know why, but I purchased my MST from summitt and this is how I fixed the problem you are haveng. I cut the studs off at the nuts all around the clutch. No more pinging and things seem to be working fine. I tALked to McCloud and they said that "maybe" the wrong length studs were installed??? but they didn't know why. I asked them about cuttng them off and they told me that that would be fine. They were right, but I still don't know why this happened. Cut the studs flush with all of the bolts and things should work out fine for you. Good luck with that clutch hooking!!
Later,
Darrell
Old Apr 23, 2005 | 09:34 AM
Actually my problem is worse. The studs took a chunk off my clutch fork and exploded my slave cylider right off its mounts I have pics here: http://www.cardomain.com/memberpage/107430/5 (site is down at the moment I think). McLeod told me to send the assy. in to evaluate the damage and then they would send replacement parts -- they did admit fault in this.
Old Apr 23, 2005 | 09:51 AM
TUFF LT1's Avatar
Dang man! That same exact thing would have happeneed to me if I wasn't carefull when I tested it for the first time. When I let out on the clutch (very slowly ) I started to hear the same noise that you heard when your clutch fork was hitting. That's when I took it back apart and shaved off thoes studs that it was hitting on. That is what ruined your clutch fork is the studs. don't put your new fork back in there until you cut the studs flush with the bolts or it will happen again. Or you can send it back to Mcleod and they will be able to put shorter studs in. ( I'd just cut them off ) That is what Mcleod told me to do. And about your master cylander... That's kind of handy though, you had to take it out to put your adjustable in there anyway right. Good luck man
Old Apr 25, 2005 | 01:56 PM
Yeah we are the only two people on this board that had this problem. McLeod wants me to send everything back in, and that is what I will do. They say they will inspect it, but it's probably their fault (duh!) and they promised to send me one of their nifty metal slaves plus I will demand a new clutch fork. Great customer service if you ask me, so I'm not too pissed anymore
Old Apr 25, 2005 | 02:15 PM
TUFF LT1's Avatar
Yea...I'm glad to hear that you have figured out the problem. I knew that it was the same thing as soon as I read your thread. I didn't damage my clutch fork as bad as you did but if I did I'd be as mad as you. Glad to hear that you got things straight with them. They really are a good company to deal with.
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Don 97 SS
Jul 11, 2005 08:50 AM
