McCloud Single Disk
McCloud Single Disk
Can you use the McCloud single disk with a stock Pressure plate and throwout bearing or would I need to change them as well. I need a new clutch and I am on a budget. Thanks.
Re: McCloud Single Disk
Yes you can. Almost all of our PPs are Valeos. I am putting a single disk in with my specII PP. My PP has some hot spots but is still smooth. Hope it works out.
Won't be running for another week or so.
My take on it. Last time i used a used clutch setup I regretted it. Worked fine for about 3k miles then the throwout bearing started to squeel.
Don't know where to get one cheap, but if you can find one swap it. I am pulling a bearing off another PP because mine was making some bad noise last time.
Not worth the trouble to pull the tranny again for 1 little bearing.
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
