McCloud Single Disk
Old Jan 23, 2006 | 12:41 PM
buzz12586's Avatar
McCloud Single Disk
Can you use the McCloud single disk with a stock Pressure plate and throwout bearing or would I need to change them as well. I need a new clutch and I am on a budget. Thanks.
Old Jan 23, 2006 | 01:22 PM
jsetzer's Avatar
Re: McCloud Single Disk
Yes you can. Almost all of our PPs are Valeos. I am putting a single disk in with my specII PP. My PP has some hot spots but is still smooth. Hope it works out.
Won't be running for another week or so.
Old Jan 23, 2006 | 01:46 PM
buzz12586's Avatar
Sweet. I am gonna get the flywheel resurfaced and just reuse the pressure plate. Will I need a new throwout bearing or can I reuse the old one??
Old Jan 23, 2006 | 01:49 PM
jsetzer's Avatar
My take on it. Last time i used a used clutch setup I regretted it. Worked fine for about 3k miles then the throwout bearing started to squeel.
Don't know where to get one cheap, but if you can find one swap it. I am pulling a bearing off another PP because mine was making some bad noise last time.
Not worth the trouble to pull the tranny again for 1 little bearing.
Old Jan 23, 2006 | 05:08 PM
buzz12586's Avatar
Alright, I'll see if I can pick up a throwout bearing. The pressure plate will be alright to use again correct???
Old Jan 26, 2006 | 01:00 AM
blown383's Avatar
I also wanted to reuse my Centerforce pressure plate along with a Mcleod disk. Has anyone done this? I can't afford a twin street right now.
-B
IndyZman
Oct 22, 2015 02:17 PM
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
hcarrickz3
Jul 21, 2015 08:46 AM
