Master Cylinder shaft isn't long enough?
Old Apr 17, 2024 | 09:12 PM
slow.z28's Avatar
I just replaced the master cylinder, slave cylinder, and reservoir in a full set from AC Delco on my 95 z28. It appeared to be the same but once fully installed the clutch pedal is about 2 - 3" away from previous position (in line with brake pedal) and the clutch doesn't fully disengage when pushed to floor. I read some reviews that said that they had to "extend the master cylinder"?? but I'm not to sure what that entails. If anyone has encountered this problem feedback would be greatly appreciated.
Last edited by slow.z28; Apr 17, 2024 at 09:49 PM. Reason: Just wanted to specify what car
Old Apr 17, 2024 | 11:19 PM
Re: Master Cylinder shaft isn't long enough?
Just a heads up - not a lot of people left on this site, fortunately most of them are 4th Gen owners. May take a while to get responses.
While you wait, might want to download a (free) copy of the 1995 factory service manual. May address your question.
https://www.mediafire.com/?40mfgeoe4ctti
Old May 10, 2024 | 09:04 PM
slow.z28's Avatar
If anyone else runs into the same problem, I fix it by cutting the shaft and cutting thread on both ends. Then put a coupler nut and two jam nuts on either side so it could be the perfect length/adjustable. Worked fine and had no problems with over 1000 miles of driving.
Old May 10, 2024 | 09:40 PM
Thanks for the follow up. Wish everyone would do that.
Old Apr 17, 2025 | 12:44 PM
slow.z28's Avatar
Update: My pedal felt a little off when getting towards the floor and it looked a little lower than normal even when untouched. I got under the dash and saw that one of the jam nuts had came lose. I adjusted the coupler nut to give the pedal the proper height and retightened everything. I suggest either really cranking down on them (which is hard when still under the dash) or potentially using something like Loctite. My car does have a look of vibration which could be cause for this but either way.
Rod Bender
May 16, 2015 02:16 PM
SilverZConvertible
Apr 30, 2011 07:30 AM
RedZ28Beauty
9
Mar 4, 2006 02:13 PM
HardcoreRM125
Oct 26, 2004 07:06 PM
wonbadassz28
Oct 18, 2004 08:34 PM
