Manually Locking Converter
Old Mar 14, 2010 | 07:27 PM
veganomics's Avatar
95 4L60E fully built with a 3400 converter. I did the swap from an M6 and I think I have everything wired up as it should ( Brake switch, etc).
The converter doesnt lock UNLESS I ground D11 (Tan and Blk) Running to the TCC solenoid "T", in which case it locks up nicely. Also, I get no codes by doing this.
I dont DD the car and really only need lockup driving the 30 miles or so to the track while in OD.
Can I manually lock this thing up (with a switch) while in OD on the trip with no ill effects on the trans? like you could on a 700R4.
Thanks guys
Old Mar 16, 2010 | 10:01 AM
Performabuilt's Avatar
Supporting Vendor
If the swap was done correctly you should not be having this issue, However yes you can lock it the way you are however it must not be locked during any shift up or down doing so can cause severe damage to the trans and or converter.
Old Mar 17, 2010 | 06:41 PM
veganomics's Avatar
Thank you. I will also check into my setup to see why its not working through the PCM.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Heathen1
Jan 2, 2016 04:27 PM
