manual oil change
Old Sep 12, 2003 | 04:19 PM
morb|d's Avatar
Question manual oil change
there doesn't seem to be much about changing manual tranny oil on this forum. its probably in a chilton's manual but i'm too cheap to get one just for that.
has anyone changed their tranny oil before? anything to watch out for? this is for the B-W T5 that comes with the V6. but i imagine it would be similar for most manuals. it looks like the "hardest" part will be draining the oil.
anyway...
Old Sep 13, 2003 | 09:30 AM
Red95Formula's Avatar
I dont have a T-5 but on my 6 speed all you do is remove the drain plug and let it drain. Once its finished just refill. Again i havent touched a t-5 but should be similar
Old Sep 13, 2003 | 12:01 PM
m0nk's Avatar
I changed it when I changed my clutch, so I had the ease of filling it thru the shifter
Old Sep 13, 2003 | 04:30 PM
morb|d's Avatar
yeah, i was just going to take off the shifter to refill, its woth the extra effort.
maybe you guys can answer another question then. i have about 52k on my car now. mostly highway. not much abuse or anything. its getting harder to get it into first gear at a stop and sometimes its stubborn going 1-to-2. i figure the clutch and T/O bearing should still be ok after only 52k miles.
so would an oil change help you think? or is my car telling me its time for a new clutch assembly?
Old Sep 15, 2003 | 03:36 PM
morb|d's Avatar
TTT
Old Sep 15, 2003 | 09:09 PM
morb|d's Avatar
so where's the durn drain plug and filler hole on the T5? I jacked up the car to rotate the tires today and i looked on both sides of the tranny and i saw nothing.
also I checked the clutch reserviour and the fluid looks cloudy and really dark. would boiling cause this? and if so, what would cause it to boil?
thanks.
grabbem88
Mar 18, 2015 01:25 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
