Making 4L60E manual
Old May 25, 2005 | 02:17 PM
jrformula's Avatar
Making 4L60E manual
Is there any possibility to make 4L60E manual?
Old May 25, 2005 | 08:48 PM
David94TA's Avatar
Re: Making 4L60E manual
Go here and look at TransGo kits:
http://www.bulkpart.com/Merchant2/me...0E-4L65Evbkits
Look at the third item from the top--it is a kit that converts to full manual. Also do a web search for TransGo for more info.
Old May 26, 2005 | 09:06 AM
jrformula's Avatar
Thanks for the weblink. TransGo product seems interesting.
Will it have full automatic mode in D? Any experience with this valve body kit?
Old May 26, 2005 | 09:26 AM
GetaZforgetGT's Avatar
Do a search on Google for Tranny Tricker.
Yank Converters makes a push button setup that I have some experience with and it seems really simple to use. Nothing fancy about the setup either.
Old May 26, 2005 | 10:18 AM
jrformula's Avatar
I have searched the Goolge for some hours now, but all I have is that manual 1-2-3 and backshifting at any speed. That is clear, but no luck for info about will it be auto in D.
Will try more...
Old May 26, 2005 | 11:15 AM
To my knowledge its an all or nothing deal.
If you want manual shifting the shifter must be in O/D and then you can select the gears with the buttons in the setup I've seen.
Old May 26, 2005 | 11:43 AM
EVERESTZ28's Avatar
Go 4l60-e.com You Will Find Evrything There And A Very Reputable Guys In Transmissions
Old May 26, 2005 | 09:07 PM
BadBowS10's Avatar
when you have a full manual valve body you have to shift every gear no automatic mode
greg
Old May 29, 2005 | 10:32 AM
jrformula's Avatar
What would be the good shifter to have with manual valve body? I quess the factory one will not take it long, if you shift rapidly with it
Old May 29, 2005 | 11:23 AM
jrformula's Avatar
Would this fit in to my 1994 Firebird Formula?
http://www.bmracing.com/index.php?id...subcat=1&pid=8
I noticed, that it is for 82-92 camaro-firebird. But will it go in with some modifications at all? Or what have you used?
Old May 29, 2005 | 06:53 PM
mongse_1's Avatar
I got a Pro Stick on my TH400 and love it. The only other setup I would've went with was a Turbo Action Cheetah SCS.
You'd have to make sure you get the 4-spd gate for the 700R-4 though, or modify a 3-spd gate.
Old May 31, 2005 | 06:30 PM
Z28Nut's Avatar
My TransGo kit allows manual or automatic operation and downshifting at any speed/rpm -- not always a good thing
It is not the full manual valve body but will hold first until I shift it, same with 2nd and 3rd. in drive or overdrive, it will behave like a 3 or 4 speed auto tranny.
Old Jun 1, 2005 | 03:20 PM
jrformula's Avatar
Ok, I have learned so far, that there is a possibility to make 4L60E fully manual. TransGo has a kit for that:
http://www.transmissionpartsusa.com/...-000359353.htm
It is also advised to use vacum pressure control with that kit like this:
http://www.transmissionpartsusa.com/...-035935mod.htm
Why is that good?
Any other hints for me? What should be done to the transmission to make it work good and last longer when fully manual? I have TCI Pro rebuild Kit inside the transmission already, with Corvette servo and Shift Kit. Converter is 2200 stall speed.
Old Sep 20, 2005 | 11:40 AM
Dnsean's Avatar
why not get a b&m rachet shifter, or something tht does rachet shifting, and get a reverse manual valvebody, so you just shift up every gear?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noer
Feb 28, 2015 11:29 AM
Lonemechanic
Feb 19, 2015 10:29 AM
Jul 4, 2005 05:00 PM
