Moaning noise when turning. What should I do?
Old Sep 19, 2005 | 07:22 AM
CheshireCat's Avatar
Question Moaning noise when turning. What should I do?
When I turn corners I frequently (but not always) hear a moaning noise that I suspect is coming from my rear end... It's relatively low pitch but doesn't sound like grinding.... More like rubbing... I have a stock 2.73 rear end and my car is stock... I have about 130k miles on the Z.
Any ideas what the sound may be? What should I inspect?
Thanks,
Steve
Old Sep 19, 2005 | 07:38 AM
Re: Moaning noise when turning. What should I do?
Sometimes that noise can come from the positraction unit. It can sound like a low growl or moan to a snapping and clanking sound. Try changing the lube and make sure you add some GM posi additive.
Old Sep 19, 2005 | 07:48 AM
Thanks Rob, I'll stop by the local GM dealership and pick up a bottle of the limited slip additive... I'm due for an oil change anyway, so I'll do both at the same time.
Thanks again,
Steve
Old Sep 19, 2005 | 08:39 AM
93LT1355's Avatar
Same thing happened to me when I changed gears, put some additive in it and it fixed me right up
Old Sep 20, 2005 | 12:31 PM
Dnsean's Avatar
if its not that, it may be the inner or outer bearings too ya know?
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
