M6 Reverse lockout ?
Old Aug 19, 2005 | 01:56 AM
redcamaroz28's Avatar
When I did my A4->M6 swap I didn't hook up my reverse lockout. With the stock shifter I could get it into reverse easily, but now w/ my pro 5.0 I have to use both hands to force it in. My question is can I use the accessory power with a switch in line to deactivate the reverse lockout? I realize the correct way is to splice into the wiring harness, but I do not have the time to take everything apart so this would be a temporary fix.
Ryan
Old Aug 19, 2005 | 02:37 AM
MEAN LT1's Avatar
Re: M6 Reverse lockout ?
I swear, your posting the questions I have before I get the chance too. I too have this problem now with the my new shifter. I used to be able to put it in reverse if I move a little but now I have a hard time doing that. Im thinking I might have activate the reverse lockout solenoid.
Old Aug 19, 2005 | 02:45 AM
You wouldn't happen to have a bad clutch and valve float problems too.
Anyways, what I'm thinking is the solenoid is always preventing you to go into reverse until it is given a power source, which retracts the solenoid letting you go into reverse.
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
jimlab
Oct 6, 2002 08:37 AM
Deadcarny
Aug 31, 2002 09:05 PM
