M6 Problem
Old Aug 22, 2005 | 01:51 PM
buzz12586's Avatar
M6 Problem
Went to the track yesterday and made 10-12 passes, defenetly being hard on my car. On my last pass the should be 3-4 shift became a 3-2 shift and spun the tires a little bit before I put the clutch back in. No over revving or anything. On the way home I noticed I could not shift from 6th to 5th. It will go into 5th from 4th and into 4th from 6th. But it will not go from 6th to 5th. Anyone had this problem before?
Old Aug 22, 2005 | 02:20 PM
FutureZMan's Avatar
Re: M6 Problem
I had a similar issue, it went but it was 3-4 not 5-6.
pulled it out, had it checked. Nothing appeared wrong, had them freshen up the synchros just because it was out, re-alligned everything and installed trans, everything worked fine ever since.
No clue what it was, if anything at all. Maybe synchros?
Old Aug 22, 2005 | 07:18 PM
buzz12586's Avatar
Re: M6 Problem
Yea thats what I was thinking. But it does into 5th from 4th smoothly. Just not 6th to 5th. At least I don't use that while racing.
Old May 21, 2006 | 01:40 PM
IndyPete's Avatar
Re: M6 Problem
Is there anyone that knows what this could have been? I've got the same problem after a weekend of dragracing.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
