M6 not wanting to go into 5th after engne rebuild!!!
Old Jun 4, 2006 | 09:53 PM
blackztpi's Avatar
i redid the motor again and pulled the trans with it. i did not alter the transmission internals. I did pull off the bellhousing and check the input shaft, which is a simple task and requires no disassembly of the internals at all. i put everything back in and put it in the car. now it doesn't want to shift into reverse. i have to really shove it over to get past the 5th-6th gear gate and into the reverse gate. once there, i can push the shifter up into reverse seemingly okay. I'm not sure what i did or what happened. I used regular dex 3 ATF and the shifter was installed correctly. not sure what to do. i know bret bauer says he is having the same problem on an ls1 car. mine is an lt1 car. any thoughts?
Sergio
Jan 27, 2016 04:27 PM
NewsBot
Jan 8, 2015 11:29 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
