M28 trans with 3.42's or 3.23's?
Old May 31, 2004 | 07:21 AM
dhirocz's Avatar
I did a swap into my '94 3.23 A4 equipped car using an M28 tranny. It works fine and has plenty of low end grunt, but was considering a bump to 3.42's to help keep my car from surging in gear (mild just under 45mph). Has a 224/232 grind in it now that I'll be swapping to a cc306 soon. It runs 2100 at 80 mph, and will only run 2250 with 3.42's.
M28's came originally with 2.73's. Is it worth changing gears from 3.23's to 3.42's? I'll be adding a torsen HD posi and cover so I'll be down there to do it...
Old May 31, 2004 | 07:59 AM
unvc92camarors's Avatar
are you sure m28's have 2.73's stock?
i thought it was m29 2.73 and m28 3.23 (because the m29 is the viper tranny right? and has a steep first gear ratio)
maybe i'm wrong, i can't quite remember
Old May 31, 2004 | 08:16 AM
Valkyn71's Avatar
m28 came in 93 cars with 2.73s, m29s with 3.23s.
and i hope the m29 is the viper, i just bought one
Old Jun 1, 2004 | 06:52 AM
IDOXLR8's Avatar
The M28 does have a 2.73 gear. And lets just say the tranny can take some power.
Old Jun 1, 2004 | 07:06 AM
dhirocz's Avatar
Yup. What gears are you running with your M28, IDOXLR8?
Old Jun 1, 2004 | 08:05 AM
IDOXLR8's Avatar
I am running a 3.50 gear but for a setup like yours I would recommend a 3.73.
blac94Z
Mar 6, 2015 07:55 AM
blac94Z
Mar 2, 2015 06:03 PM
TitoPR221
Jan 29, 2015 08:00 PM
Jul 4, 2005 05:00 PM
