M 6 second gear problem?
Old Jan 7, 2005 | 02:45 PM
BadgeZ28's Avatar
I just got a 01 Z-28 with six speed trans. The shifter has a leather ball with a big H so I assume it is a Hurst short shifter???? Anyway, going from first to second feels like I have to force it. No syncro noise, no grinding, just a non smooth transition. Is this normal, or a shifter problem? Thanks
Old Jan 7, 2005 | 05:38 PM
Cstick's Avatar
Re: M 6 second gear problem?
No its not normal. I have the same problem, but it was not always that way. Mine does not grind either but I am pretty sure the 1-2 syncro is worn. All other gears shift fine, I just try to either skip 2nd if I can or double clutch 1-2, until I have time off to fix it.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
