M-6 Question
Old Nov 14, 2004 | 08:37 PM
97Transam123's Avatar
M-6 Question
HI, i have a 1997 pontiac T/A and when ever i get on it or rev it my shifter moves up and down, is this a sign of trany mounts going? or is this normal?
Old Nov 14, 2004 | 08:50 PM
roguedriver's Avatar
Re: M-6 Question
Could be a broken tranny mount, or could be the nut for the mount is just loose. Gonna have to get under there and take a look.
Ken R.
Old Nov 14, 2004 | 10:26 PM
Fast Caddie's Avatar
Re: M-6 Question
Mine did the same thing.... the tranny mount was shot... the rubber had cracks in it all the way around. Switched to an LS1 mount and it's solid and smooth.
Note... if you switch to the LS1 mount like i did, you'll have to do a little bit of grinding on the exhaust hanger bracket that stems from the rear of the trans. It's not very much, you grind just enough so the mount can sit flat on the mounting surface. Takes 5 minutes and the LS1 mount is almost as strong as the 1LE mount. When i went to order the 1LE mount from Jason Cromer, he told me the 1LE has been discontinued and replaced with the LS1 mount. It's basically the same thing so that's why GM did it.
Old Nov 15, 2004 | 06:14 AM
Re: M-6 Question
ok thanks guys ill get right to it
Old Nov 15, 2004 | 02:35 PM
madwolf's Avatar
Re: M-6 Question
Some may not agree, but I would recommend an Energy Suspension polyurethane mount. Available at an Autozone near you!
Say goodbye to any shifter movements with that mount.
I've also had the LS1 mount and did not have to grind anything.
Old Nov 15, 2004 | 04:47 PM
Re: M-6 Question
hmmm.... don't know madwolf. i had to grind the bracket at the area above the bolt holes or the mount wouldn't sit flat on the trans surface. Wasn't much trouble to do at all. It was a GM mount i bought from Cromer with GM tags all over it. It's taken a beating over the last year and still solid. As long as it works i don't care
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
OneBad98Z
Aug 9, 2002 08:21 AM
OneBad98Z
Aug 6, 2002 03:23 AM
