LS1 transmission mount... *PICS*
Old Apr 5, 2006 | 12:25 PM
Drowned's Avatar
Red face LS1 transmission mount... *PICS*
Just got it in the mail. I'm replacing my poly mount on my LT1 cause the vibration is driving me crazy Hope the pics helps somebody out...
Part number is: 22174970
Old Apr 5, 2006 | 04:19 PM
Drowned's Avatar
Re: LS1 transmission mount... *PICS*
Just installed it... car feels sooo smooth now
Old Apr 5, 2006 | 06:35 PM
MeanGreen97Z's Avatar
We can use this on an LT1?
Old Apr 5, 2006 | 06:51 PM
12SCNDZ's Avatar
You'll break the LS1 mount if you're making alot of torque. When you had your poly mount on, did you have the spacer between the mount and case? If you install it, it will give you an unbearable vibration. Taking it out helps alot.
Frank
CPT
Old Apr 6, 2006 | 12:00 PM
Drowned's Avatar
Yes, you just need a nut... I think it's 7/16 and that's it...
Old Apr 6, 2006 | 12:02 PM
Drowned's Avatar
Frank
CPT
Nope, no spacer... everybody that's using the LS1 mount says they haven't been able to break it
Old Apr 6, 2006 | 12:16 PM
Bow94z's Avatar
depends on driving style..i put the LS1 mount on my car, you just gotta grind a lil piece to clear the Cat mount...
Old Apr 6, 2006 | 12:55 PM
19z28camaro02's Avatar
Energy Suspension does a good poly mount. I broke the OE rubber one on mine and went to http://www.ls1speed.com and found it under suspension near the bottom.
Old Sep 14, 2007 | 12:48 AM
chevelles101's Avatar
Drowned, is there anyway you could upload those pics again? I would greatly appreciate it.
Old Sep 17, 2007 | 06:42 AM
Capn Pete's Avatar
I've got about ~70k miles on my car now, and with the exception of running the Energy Suspension poly mount for maybe ~5-10k, I'm still running the original (LS1) trans mount. I have raced my car SEVERAL times on the drag strip, and in the last couple years, quite a few times on road courses. TRUST ME, the road course is more abusive! (already cost me a set of 4.10's and the 4L60E tranny! ) ..... and I'm STILL on my factory mount .
I couldn't stand the vibrations with having the ES poly mount ... and I had the plate removed.
Old Sep 17, 2007 | 03:18 PM
Thanks for your input Pete, I've tried purchasing the ls1 trans mount at a local OReilly but the mount they showed me had two studs coming out to bolt to the trans brace instead of one like the stock lt1 mount. Did they show me the correct mount and I just need to modify the trans brace or did they show me the wrong thing?
Old Sep 18, 2007 | 02:43 PM
Capn Pete's Avatar
The stock LS1 mount should just have 1 stud off the bottom, same as the LT1 mount. You're probably best getting it at the GM stealership .
Old Sep 18, 2007 | 10:14 PM
Well if it comes to that I think I'll just get it gmpartsdirect.com, but thanks for your help.
rideordie
Nov 5, 2019 04:52 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
