Loud Bang/Knock on acceleration or downshift
Old Aug 14, 2010 | 12:16 PM
mikesta04's Avatar
Last night i was test driving a potential project. (94 z28) and when i tried to accelerate relatively hard there was a bang that seemed to come from between the drivers and passengers seat, obviously from underneath the chassis. This also happened when i attempted to give it some gas and the auto trans attempted to shift from 3rd to 1st, as it had just gone to 3rd and the rpms were low. It shifted after the thud; but this is obviously a large issue. The sound/thud also happened multiple times during one particular acceleration from 0.
Specs:
170k miles.
Stock.
Auto Trans.
I know there is a low probability of anyone having had this issue before, but any advice would be appreciated.
Thanks for your time.
Old Aug 14, 2010 | 01:35 PM
Check the tranny mount - sounds like its broken.
Old Aug 14, 2010 | 01:49 PM
mikesta04's Avatar
ok
Would i have to take that to a shop to check it or can i do that myself.
Old Aug 14, 2010 | 03:21 PM
Safely get under the car. Put a jack under the tranny, and start to jack it. If the tranny tailshaft lifts off the mount/cross-member, the mount is broken. With the jack supporting the tranny, unbolt the mount from the cross-member, and then unbolt the 4 bolts that hold the cross-member to the chassis. Unbolt mount from tranny. Reverse procedure to install the new one.
Very simple.
Old Aug 14, 2010 | 03:29 PM
onefastmx5's Avatar
Like he said, get under the car and look. Check trans mount, then U joints, torque arm mount, pinion play, hardware, etc.
Old Sep 19, 2010 | 12:04 PM
mikesta04's Avatar
It was the trans mount. Thanks for the advice!
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
CARiD
Sep 7, 2015 08:21 AM
