Lockup connector on 700R4
Old Apr 7, 2008 | 03:57 PM
  #16
PWR SHFT's Avatar
I would really like to know this too. My car is 95% track and I do not need the convenience of the automatic lockup. Plus, I would like to keep things simple for me to hook up. I am not a wiring guy!
Old Apr 7, 2008 | 05:24 PM
  #17
northdakota93z28's Avatar
just leave the 4 pin connector off. the stall will never lock then.
Old Apr 7, 2008 | 05:30 PM
  #18
12SCNDZ's Avatar
Your best bet would be to put a non-lockup valve conversion in the pump. This changes the lube circuit, and gives the 3-4's the cooling they need, without lock-up.
Frank
CPT
Old Apr 7, 2008 | 09:55 PM
  #19
marshall93z's Avatar
Originally Posted by marshall93z
Is the switch on the far right the 4th gear pressure switch? And if so, what is the one in the middle?
Old Apr 7, 2008 | 10:05 PM
  #20
12SCNDZ's Avatar
The switch on the right is the 4th switch. The other one in the picture is a temp. switch. I haven't answered this until now, simply because I don't want to be a part of you doing this wrong, as you are choosing to do.
Frank
CPT
Old Apr 8, 2008 | 11:46 AM
  #21
Thanks! You're definitely not part of it. If I mess it up, I know whose fault it is.
Old Apr 8, 2008 | 12:25 PM
  #22
Another question for you...
The wire comes from the 4th switch and goes to the temp switch, then from there to the computer. Then the switched ground comes back in, but goes to the temp switch first. Why does it do that an not just go straight to the ground side of TCC solenoid?
Old Oct 25, 2008 | 03:03 PM
  #23
PWR SHFT's Avatar
Did you ever have any luck with this?
Old Oct 27, 2008 | 11:01 AM
  #24
Yep. It's been going strong since whenever I got it going.
Back in May or April.
Old Oct 27, 2008 | 03:16 PM
  #25
PWR SHFT's Avatar
How did you end up wiring it up?
Old Oct 28, 2008 | 11:34 AM
  #26
It's been so long, I forget exactly what I did. I do know that I used a toggle switch, though, and I think it's on the power wire.
Old Dec 21, 2009 | 06:54 PM
  #27
Just an update...
I have over 25,000 miles on this now with no cooler and NO problems. Tranny has almost 200,000 miles on it now. Came out of a 91RS with 167,000 + my 25,000.
Jeff1904
Jun 5, 2016 05:00 PM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
