To Locktite or Not???
Old Nov 1, 2007 | 01:48 PM
DAVE00's Avatar
Question To Locktite or Not???
Guys,
I'll be putting the T56 back in this weekend along with the new clutch and resurfaced flywheel. A question:
Do you used locktite on the following and what color (red/blue)?
Flywheel bolts to crank
Pressure Plate bolts to flywheel
Bell Housing bolts to block
Tranny bolts to bellhousing
Cap bolts on rear driveshaft yoke
Shifter Plate
Old Nov 1, 2007 | 01:52 PM
mdacton's Avatar
only a vary small amount on the crank bolts...red
nothing else. matbe some anti seaze on anything that goes in aluminum....
Old Nov 1, 2007 | 01:54 PM
DAVE00's Avatar
Thanks Mdacton!!
Old Nov 1, 2007 | 04:31 PM
wrd1972's Avatar
Originally Posted by DAVE00
Guys,
Shifter Plate
I use blue on the flywheel bolts and especially on the pressure plate bolts since they only torque to 22#. None nedded on the other locations.
This is the first time I used blue, I normaly use red but I want to reduce the risk for disassembly damage in the future.
Old Nov 1, 2007 | 05:27 PM
Kevin Blown 95 TA's Avatar
I use blue 242 also. Torque holds them in, the locktite just keeps the vibes from rattling them out. Not that red 271 would hurt, but it does make it more of a bear to remove unless you use the air tool or a little heat. I got about 6 kinds of locktite and its one of the best products out there that does exactly what it says it will. The hydraulic 245 is a godsend if you ever have a leaky anything.
Old Nov 2, 2007 | 07:22 AM
DAVE00's Avatar
Thanks Kevin, I'll prob stick with the blue as well, I appreciate everyone's input.
Old Nov 3, 2007 | 11:17 AM
94Camaro_Z_28's Avatar
I use it on the flywheel to crank and pressure plate to flywheel bolts. I used the red because it's what I had...blue would've been prefered. Other than that the other bolts will be torqued down plenty to stay in place.
Old Nov 3, 2007 | 03:08 PM
Green96Z's Avatar
I used red on the clutch fork pivot bolt, read stories on here about that thing backing off. Didn't use any on my ARP flywheel bolts, wondering now if I should have...
Old Nov 3, 2007 | 04:30 PM
Well I was gonna say that I've never had flywheel or pressure plate bolts come loose in my life before I ever used locktite. If you tightened them correctly, they should be OK. Locktite is kind of like safety wiring - on a healthy correctly torqued fastener - it's extra insurance. On anything that vibrates a lot like a Harley, Locktite is more of a must have item.
Old Nov 3, 2007 | 09:44 PM
DAVE00's Avatar
Thanks to everyone. I put her all back together tonight and OH MY GOD, it hasn't shifted that smooth since she was new. Worked out great and I appreciate all your input.
LT1 POWR
Mar 21, 2011 11:22 AM
Dr. Weir
May 31, 2004 09:46 PM
BradZ28
Oct 3, 2003 11:29 AM
96z
Apr 5, 2003 01:31 PM
trax
Mar 12, 2003 12:56 AM
