What bolts/studs require sealant/locktite?
Old Mar 20, 2011 | 11:38 PM
LT1 POWR's Avatar
Anybody have a complete guide as to what bolts or studs require either thread sealant or locktite when rebuilding a motor?
I know obvious thread sealer studs, like head studs and rocker studs, but are there any others I'm missing?
Should locktite be used on pretty much everything else or do only a few nuts/bolts require it?
Also is seams that permanex high temp thread sealer is the one to use.
Old Mar 21, 2011 | 11:22 AM
RamAir95TA's Avatar
Re: What bolts/studs require sealant/locktite?
If the hole is blind, you don't need anything.
If it protrudes into coolant, oil, or vacuum, use thread sealant. Permatex is what I use.
If you don't want it to come loose, use loc-tite.
If it goes in the exhaust, use anti-seize.
Sep 27, 2015 01:55 PM
Aug 24, 2015 06:41 AM
4586
Aug 13, 2015 10:11 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Wilson
Jul 21, 2002 05:08 PM
