Leaking Tail Shaft...
I have a tiny amount of play in my driveshaft where it sticks in the tranny (about 2mm of it). The trans is also leaking small amouts of fluid out around the drive shaft seal/boot onto the tail shaft housing. What do I need to do to get the leak fixed considering how difficult it is to check the fluid level.
Could a wobbley driveshaft and a poly trans mount cause this...as I have both....I think
