Just Finished Spec 3 Install
Old Sep 21, 2006 | 07:40 PM
  #16
JustNO's Avatar
Re: Just Finished Spec 3 Install
Originally Posted by JoeliusZ28
thats the way the clutch is. Youll find that the faster you let the clutch out, the better it behaves. I often chirp the tires taking off because thats better than dealing with chattering. The SPEC 3 needs pressure put on it. it doesnt like slipping under small ammounts of pressure. It is DESIGNED for handling large ammounts of torque, and most driving around isnt a high-torque scernario. by the way... mine didnt break in fully until 2500 miles. at that point i got frustrated with it so I intentionally flogged it and got it hot. it was 50% better the next day That being said, its still not an easy clutch to please.
wait wait I hope I didn't pay 680$ for no reason. When I hardly press the gas pedal on 3rd shift at 3000rpm, I feel its slipping, I even can heard the sound of exhaust slipping with clutch. And the car doesn't accelerate well.
Old Sep 21, 2006 | 07:52 PM
  #17
JoeliusZ28's Avatar
if your clutch is slipping after being installed... theres a good chance something didnt get put together right. if theres one thing my spec 3 doesnt do its slip. ive chirped 4th a couple of times.
Old Sep 21, 2006 | 07:59 PM
  #18
JustNO's Avatar
it was not slipping at first. When it started to slipping, I removed the clutch and saw it was not regular color, was black color. (burned?) The thing is, this is my first clutch experience. (you can see on my sign I did swap from A4 to M6). So I didn't know that I should wait clutch breakin. I didn't wait for breakin. I think thats the reason. Bad experience.
Old Sep 21, 2006 | 08:03 PM
  #19
JoeliusZ28's Avatar
it was not slipping at first. When it started to slipping, I removed the clutch and saw it was not regular color, was black color. (burned?) The thing is this is my first clutch experience. (you can see on my sign I did swap from A4 to M6). So I didn't know that I should wait clutch breakin. I didn't wait for breakin. I think thats the reason. Bad experience.
depending on what you did to it, that could be the reason. I wouldnt think it would be that easy to mess up though.
Old Sep 22, 2006 | 02:21 PM
  #20
97formulakid's Avatar
Breakin has a lot to do with the life of the clutch. It could be possible that since you didn't break it in, it is slipping really bad.
Old Apr 20, 2008 | 06:08 PM
  #21
bt96ss's Avatar
maybe you have an oil leak. My camaro has a fairly new slp clutch in it. It also has a rear seal oil leak. It slips like crazy. I took more time with my TA and its been alot better.
Old Dec 24, 2009 | 04:43 PM
  #22
paxtonLT1's Avatar
clutch brake in is overrated i allways just sliped it with the brakes on tell it got hot then let it cool down then repeated. it allways worked well for me. you try and tell a customer they have to drive there car a certen way for 500+miles and see what they say.
Old Dec 27, 2009 | 08:57 PM
  #23
mzgp5x's Avatar
I've had two (2) Spec 3's on an Alum fly behind a 383 D1 blown. All have chattered upon slow engagement. I engage it fast and no problem. Also, a slipping clutch could be a hyd line restriction, since, gm installed a small oriface to bleed pressure slowly (you know... drivability). Not a good thing for modding. Possibly a cleaning or a drilling of the orifice (inside the line) would be in order. I've seen other posts on this. I punish my clutch. B.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
Collector Car
Jan 5, 2015 10:58 AM
