i bought my fist camaro but......
Old Feb 13, 2009 | 02:50 PM
grimjeeper73's Avatar
i bought a 95 camaro z-28 off my father in law it has 63000 miles on it 6 speed manual Bose stereo and i got it for 1000 dollars but.. the clutch in it is fried i have a lot of mechanical experience but is this something you can do in your driveway i also have to replace the rear main seal which is leaking due 2 sitting in a garage for three years i ordered a f1 stage 2 clutch for it and i hope that that is sufficient for this car. i am going to put this clutch in this week so any tips or pointers would be much appreciated
Old Feb 13, 2009 | 06:04 PM
Green96Z's Avatar
Welcome to the forum.
There is a sticky about LT1 clutches at the top of this section with some good info in it. The clutch install is not too bad, I just did it a couple months ago. I'd recommend renting a floor tranny jack (unless you have a lift), get some ramps and jack stands and get the car as high as possible.
Definitely go with a pilot bushing, not a bearing. The best way to get the old one out IMO is to use the wet toilet paper method. Worked great for me.
Use some long extensions for the tranny bolts, and remove the tranny from the bellhousing first. Don't forget to pull the shift fork down first! The top left bellhousing bolt is the hardest. I use a prybar and a swivel socket.
For the rear main seal, http://www.pharmacy.arizona.edu/staf...RMainSeal.html
That's just off the top of my head, I'm sure others will post up any other tips I forgot.
Old Feb 14, 2009 | 12:24 AM
camaro1fastz28's Avatar
the pilot bearing i like to use a dremal and grinding bit to put a cut down it makeing sure not to cut the crank and then pry it out with a screew driver
Old Feb 14, 2009 | 01:50 AM
thanks great info
Old Feb 17, 2009 | 06:13 AM
what is the wet toilet paper method?????
Old Feb 17, 2009 | 09:47 AM
dfrank's Avatar
Yeah the toilet paper method:
Originally Posted by wrd1972
You can take toilet paper completely soaked in water, pound a bunch of it it in the pilot bearing hole with a socket extension and the pilot bearing will work its way out of the crank. Sounds crazy as Hell, but I called BS on it then ate crow when it actually worked.
Never tried it myself but next time...
Anyway, cool car you have picked up for a song. Now go have fun with it.
Old Feb 17, 2009 | 07:24 PM
Green96Z's Avatar
That's where I got the idea. I used a 1/2" extension, fit perfect, and the bushing came out like butter. Just close your eyes and mouth, cuz it might shoot out at you.
Old Feb 18, 2009 | 01:05 PM
JohnD's Avatar
For that top left bellhousing bolt that is so hard to reach, use a 1/4" drive 14mm swivel socket. The kind where the socket itself swivels, not a swivel attachment.
You are going to need about 2 feet of extension to use reach the top bolt and it is even easier if you put a flex fitting in the middle of the 2 feet where it goes over the transmission.
You might be able to lift the tranny but I can't, I made a bracket of a piece of plywood with two pieces of 2 x 4 nailed to it so the the tranny bottom had a grove to sit in. That on a floor jack with a ratchet strap around the tranny to hold it worked fine for me.
Old Feb 18, 2009 | 07:59 PM
got it out bell housing and clutch off tomorrow
well i finally got it out no jack on the tranny. that thing was heavy lol i spent about 4 hrs on it but two of them were wondering why it wouldnt come all the way out untill i realized u had two take the clutch engage off to hopefully no more headaches to come i will say it would be easier to have a tranny jack but u work with what u have i guess
Old Feb 18, 2009 | 08:34 PM
raroz28's Avatar
Let us know how that F1 clutch kit works out for you. I saw them on eBay and they were really affordable. i wasn't sure about the quality of it.
Old Feb 18, 2009 | 09:56 PM
it was supposed to be an f1 but they sent me (Competition Clutch) instead i same price i will tell you how good the product is though
smokin25th
Jan 1, 2015 09:06 AM
fpete1992
Dec 11, 2014 03:51 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
bernie1951
Dec 10, 2014 10:03 AM
